Originally Posted by
Skyhawk940
I can tell, you've built a few planes from scratch. Teach the younger generation or this skill will die.
Building RC airplanes and building and fixing things in general is just slowly dying. When I got back into the hobby I could not find any kits locally. I also found out how the hobby had changed. In the past, you had to build to fly. So I just started scratch building.
A few weeks ago I was going to the Post Office and saw a baby stroller off the side of the road, country road. Figured I'd check it out on way back if it was still there. It was there turned out to be an expensive stroller. It had a bent axle and rubber tire had come off the plastic rim and rim was bent. Other than that it was in good shape but a bit dirty. May have been there a while. I took it home and had it fixed in 30 minutes. Someone may have abandoned it cause it was damaged. Probably fell off a vehicle.
