lol Going stick happy.
Will think about this over the next couple of days..
Would think that I need to put at minimum a 3/16 one on top of the wing over the new bottom one.
Dgrant, about what you said about the landing gear block, the pine blocks for the gear looked like it was cut from lumberyard number two pine stud scraps so I am not surprised it split. My buddy cut mine out of ash. Which, as far as I know is good for tool handle so it should resist splitting. Might need to to do a bit of research there and if it looks iffy. Through bolt it with 2-56 bolts and a couple small metal plates on each side will be cheap insurance. Then it will have to twist the whole block out.
