RCU Forums - View Single Post - Pattern Biplane
Thread: Pattern Biplane
Old 01-18-2018 | 08:55 PM
  #258
Pylonracr's Avatar
Pylonracr
Originally Posted by speedracerntrixie
Ok you two, enough nonsense! I did cut out a couple formers from the actual material that is being used. It is a laminate of 1/8" Divinicell with 5.7 oz carbon cloth on each side. This is some of what I have been selling to other guys as well as the fiberglass material as well. Over the next few days I will be cutting formers and getting them glued into place.
Yup, that is the same laminate I use. I need to make some more since Chris lost 2 426 planes at Phoenix last weekend...
Are you going to do the inner laminate and seam in 1 piece or tape the seam later?
Scott
