Dave,
might be an idea to use two power boxes on the two groups of gear doors, that would reduce the inputs needed from 5 to 2. Thanks
Why do you need separate output for each gear dor? What about to divide doors for two groups, one to be closed after retraction, second one to stay open. Servos inside group are connecting via “Y” cable.
So, you can use the external door sequencer and just require one output from powerbox for that (i’m using JetTronics sequencer
JETTRONIC FLEXIBLE GEAR DOOR SEQUENCER)
Regards,
Sergey
