RCU Forums - View Single Post - YS four stroke fueling methods?
Old 10-30-2003 | 02:04 PM
Phred
Default YS four stroke fueling methods?
Will a Dubro Quick-Fill fueling valve stand the pressure, or will it leak? Or should I tee the two lines near the tank with fuel dots? Will the fuel dots leak without clamps? Will all the fuel line push- on fittings seal ok without being clamped? What methods work best for you? New YS owner needs input. Thank you!
Phred
