I got the trailing edge on and sanded, mounted the outer panels to the inner panels. One tip I found helpful when sanding out a trailing edge is to put tape on the end of your sanding bar. It will keep the end of your sanding bar from tearing up your sheeting or sanding a low spot. When I sanded out the dowels I put tape on both ends of my sanding bar. When I was as close, I took off the tape and just had to lightly finish it off.
