Sounds like you must have a vacuum leak somewhere. Check carb mounting adapter for cracks, the carb gaskets, the crankcase, cylinder base, and the front seal. You might try getting it running, and shooting ether, (starting fluid), on those areas, or thick oil.
AV8TOR
