Thank you all for the reply's. It is probably going to be a couple weeks before I start covering. I mounted my servo"s a little too high in the cockpit area and going to have to redo in order to get the pilot where it should be.Decided to move my receiver back a little bit too. Thinking if I have to get to them in the future , I can do so through the cockpit I .Hate having to redo things , just a whole lot of things involved in setting it up for electric.I plan on covering the model in my outside building,14x20 which has vents in the ceiling, and a window fan that can be reversed to draw out fumes also.I am around a lot of paints, stains and sealers at work where I do maintenance, The oil based stain is not my favorite thing to do inside. I stained some doors once ,and had them placed flat down on my work table. Where the vapors were coming straight up at me ,it was extremely strong.I set up a couple fans and retreated to the outside every 10 t0 15 min.I was just curious how strong the nitrate dope really is. I know sometimes, people can over exaggerate on things.I noticed on the back of the nitrate can , that it states to use sig supercoat for filling the last coats, due to the regular clear nitrate shrinking enough. I thought I would be using the clear nitrate for this also. I don't recall this mentioned in the video, Is this necessary,
