the s
Originally Posted by
Bozarth
Hey Scott,
Nice build thread. Great pictures. What are your thoughts behind the dowel aileron servo mounts as opposed to the typical cutout slot in the wing? I have never done the dowel mounting method so I don’t know the pros/cons. Thanks!
Kurt
The method with dowel aileron servo installation works very well with this model. It has long aileron horns and installing the servo on the dowels connects very well with long horns.
I could have used a cutout. The servo would require raising a little as the wing is relatively thin in the location where the hole would be.
Either way should work fine.
