Originally Posted by
obrien135
is a radian more managable than the sport cub s or the t-28 trojan s when they are in the advanced mode? I don't think it has sae mode which is good because I want it to bemanagable without it.You say this one is good for beginners?Idon't wanttospend the money If I van't fly it.
The micro Radian has AS3X stabilization but not SAFE. The larger Radian's have no AS3X or SAFE.
Based on your info I would suggest getting the UMX micro Radian. It is only elevator , rudder, and throttle so you don't have ailerons (and the trouble they can cause new fliers) , it's small so you can fly it in smaller areas, it's easy to fly and floats well ,and the AS3X helps keep it stable in wind.
As mentioned, get you eyes fixed first and then get the UMX Radian, fly it and keep it close.
