Originally Posted by
JohnBuckner
To confirm failsafe enabled, no need to run engine just turn on Tx and Rx then turn off only the Tx and watch/listen throttle has closed. That's it.
In the case of a turbine just lite up and after ramp up and running indication on the GSU just turn the Tx only off The engine will shut down if failsafe is enabled.
John
Okay thanks John.
What about electric? uummm.... Maybe actually need to throttle up the electric, turn off the Tx, and watch the motor spin down.
