looks like your going to be running on 6s lipo battery power so a good size motor for the 6s needs to have a kv rating of between 1400 to 1700 maximum. the T.P. 4092 motor would be good. you can use a 180 / 220 or 240 amp esc, the 180 amp Turnigy esc is suited for up to 6s so its up to you how big and how much you want to spend. as for props you should start off with a smaller size and work up if needed. try an Octura x447.
