Originally Posted by
drac1
Claude's method of setting pump pressure is very interesting, so I thought I would check the pressure of mine. Mind you, as it is running so well, I had no intention of adjusting it no matter what the pressure was.
As it turns out, it seems Claude might be onto something. Pump pressure of the Xareltoo engine is 1.1 bar. Not far off what Claude says it should be. I may tweak it a touch sometime, but for now i'll leave it alone.
I also checked the number 2 engine in the Valiant. That was reading around 0.75 bar, so I richened it until it read 1.1 like the other one. 1/8th turn on the reg equals approx. 75-80kpa. I haven't flown the Valiant since adjusting it, so it will be interesting to see how it goes. Hopefully tomorrow.
I would think this would apply to any DZ engine. Maybe not the exact numbers but the process would apply. Now to find a small pressure gauge.
This is great information!!
Ken
EDIT: Claude in your opinion would you ever need to go above 2 bar in pressure? I'm thinking having a gauge that is as close to the max pressure seen will give greater resolution for future adjustments or confirming pressure???
