RCU Forums - View Single Post - taigen 360 roation kit...didnt work well
Old 03-02-2018 | 06:19 AM
luv2flywarbird
Originally Posted by Imex-Erik
Oh so you are saying the daughter board that is placed inside your turret came undone with then got a wire caught? I see now, you should be able to repair the wire with no real issues there. Just when you place that little board back in there add a drop or two of hot glue to hold it in place. The slip ring is made to infinitely spin so you can spin for a whole battery while shooting and elevating if you want. However you want to make sure you don't have any tension on the cables and that your firing unit doesn't put pressure or pull on the cabling as well.
no not daughter board the slip ring comes off the socket that is provided in the 360 rotation gear
and yes i made sure when barrel in moving up down the wires are not getting caught in anything.
