CA hinges on a used wing
SIG four star 60. Crashed and rebuilt a couple of times. Need to put CA hinges on the left side of one piece wing (right side already has them and they are good). Problem is the wing has already had CA hinges a couple of different times and the thin CA will not soak into wing.
1. It looks like since I have already done this a couple of times ("re-caed" and moved hinges up down wing) this idea is out.
2. I do have Robarts I could do {already know how to do these}, but I don't want to use them if I don't have to.
The main question is, can you use a thicker CA for a situation like this or there any other techniques when you run into a situation like this.
thanks.
