CA will not stick to CA. You can still use CA type hinges but use epoxy to glue them in. Pinch the end of a straw, scoop up some epoxy into the straw, insert it into the slot, even one that was used before and re-opend, then blow the epoxy in, then insert the hinge. It will work just fine.
