Big project for Horus X10S and therefor questions ;-) ?
Hello, I need a special setup for a special (airplane) project and I think the Horus X10S mixed with other technologies will the perfect match, but I have a few questions for you frSky specialists:
1- I need to program a sequence of event pretty complex,
like a door sequence, the sequence is going like this:
a. For open:
i. Open the outer door (5 doors with 9 servos, all must
be adjustable individually)
ii. Open the inner door (1 doors with 2 servos, all must )
iii. Lower the wheels
iv. Close the inner door
b. For close:
ii. Raise the wheels
iii. Close the inner door
iv. Close the outer door
2- I need 9 channels to be s-bus compatible (ideally
Futaba) to go through a Deamon Cortex Pro gyro
3- I need to be able to do 14 mixes (in addition to the
doors/wheels sequence), mainly aileron 1 to
aileron2 (with reverse and endpoint adjustment) type.
4- I need in total 27 channels, so it will be 2 receivers, one
normal (Rx8R) and a s-bus compatible (R??).
Can you tell me if its feasible and with which component I should go? (Receiver model ?) Please provide as much detail as possible as I came from a Futaba world and did use only this brand since always !
Thanks a lot!
Reason: Moving the title to the right place ;-)
