Originally Posted by
Tom Nied
I just looked at mine. The right thrust is almost negligible. So try to make measurements before you start adding right thrust. Because on mine, it's very little. Hope that helps.
Thanks Tom! Right now my plane would probably make a left turn on its own with all the left thrust out of the box. It's that bad. LOL! I understand you have a slight right thrust, that's probably all it needs, Please explain make mesurements. Also, if it is not too much trouble, would you be able to take a photo looking down at the engine so I can get an idea how much right thrust you have.
Thanks!
John
