RCU Forums - View Single Post - Calrl Goldberg Tiger 60 Build
Thread
03-25-2018, 11:56 AM
371
VincentJ
Tiger 60 Specification/Parts Build Sheet
Flying Weight- 9.92 pounds
CG- 4-1/4"
Wheels- 3-1/2"
3.5"-89mm Eight Spoke PU Wheels(pair)_Wheels(Tire and Rim set)_Welcome to SPOTONRC
Engine- DLE-20RA
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXDWDW&P=0
Fuel & Oil Mix- Red-line Two Stroke Racing Oil (40 to 1)
Prop- Falcon 16x8
https://www.falconpropellers.com/pro...blade-16-x-08/
Spinner- Tru-Turn 2-3/4" Standard Profile
Tru-Turn: Welcome
Battery- Life 3200 mAh
https://lifesourcebatteries.hobbico.com/hcam6446.html
Battery Balance Lead Extension- Venom 200mm
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXGYGV&P=7
Spark Plug- NGK CM-6
Gas Tank- 12 ounce
Fuel Dot- Spot On RC
Single Fuel Dot(Magnet Style) _Dots And Switches_Welcome to SPOTONRC
Fuel Line- Sullivan ProFlex
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXGFHS&P=M
Engine Kill Switch- Ultra IBEC
Ultra IBEC - Tech-Aero Designs LLC
Wood Glue- Titebond II
https://www.towerhobbies.com/cgi-bin/wti0001p?&I=LXHS58&P=0
Epoxy- Bob Smith 30 minute
Rudder Hinges-
https://www.dubro.com/collections/hi...y-nylon-hinges
Elevator and Aileron Hinges-
https://robart.com/collections/contr...hinge-points-6
Landing Gear- DuBro
https://www.dubro.com/collections/la...h-landing-gear
Aluminum Wing Tube- TNT
Welcome to TnT's Online Catalog
Wing Bolts- Secraft
http://www.secraft.net/shop/step1.php?number=1241&b_code=B20090803051116&ckattempt=1
Wing Servo Extension Leads- Tail Dragger
20 AWG 6" Male 20" Female MPX Single Harness - Taildragger Rc, LLC
Covering- UltraCote
Ultracote: Hangar-9
Note: This list will be updated periodically
02:40 AM
Reply
Like
VincentJ
View Public Profile
Send a private message to VincentJ
Find More Posts by VincentJ
View iTrader Profile
