RCU Forums - View Single Post - Tamiya recoil issue
Old 03-28-2018 | 07:16 AM
Cruiser133's Avatar
Cruiser133
I tried about 5 or 6 times resetting it per the manual then I finally took it apart or at least took off the top cover and discovered a bit of corrosion. I used some rubbing alcohol and a q-tip and cleaned the top of the board but I have not accessed the bottom yet. Anybody know if these are glued to the bottom shell? I am pretty sure I have some corrosion making a connection along some trace on the board which is providing the constant low power to the recoil outlet.
