Hi Barrie, hopefully will make it on the 22nd. The DLE rear exhaust seems like a good option and it is if you are using a commercial can. However if the can is right up behind the motor the side exhaust header can enter the side of the can. Off course this requires a custom header and can. Need to see how it works out in practice but building one should be easier than 2x ZDZ 120 pipes I did for the Jungmann .
