Hi Guys,
I have now started the build on my Mini Avanti which will have the K45 fitted. Need some advice on the following:
A) Tail pipe: I have a spare HSD Super Viper tail pipe available, i trial fitted it and it looks just perfect as the rear former holds the pipe exactly in position. except for a couple of issues: pipe seem a little long and protrudes outside fuselage by 5 to 6 cm would this be a problem? on the other hand the outside pipe is pulling against the CF Stab rod, Would this be a problem?
B) Still not sure about which Fuel tank to use as i would have to remove (cut out) the the inlet liners as no decent fuel tank would fit in this narrow space and moving fuel tank forward is out of the question for sure.
Any help/feedback on the above would be much appreciated.
Regards,
