Originally Posted by
the Wasp
Dave, not much different there, is there ? but enough.. so the 115 has a different part number than these two, I am wondering it's ID is between the 100 and 125
so what about the OD of their Intake Manifolds, are they different sizes ??
Jim
Hobbsy
The 1.25 intake pipe measures 10.5 mm at the bottom and 11mm at the top
The 1.00 intake pipe measures 10 mm at the bottom and 10.5 mm at the top. I measured around the circumference to make sure the curve was not causing the difference. They are both straight at that point. Interesting.
Does anyone have an FA-115 to measure the intake manifold? I would to know if the 125 is the same size as the 115 manifold where it enters the head. They both use the same valves.
