RCU Forums - View Single Post - Pull-Pull for rudder in 2M planes - recommendations.
Old 04-07-2018 | 04:10 PM
grotto2's Avatar
grotto2
This is a horn developed by the late Sam Turner. I've used it for many years. A dowel is drilled and tapped for 4-40 and epoxyed into a hole cut with a piece of serrated brass tube. It can be slightly adjusted for centering by bending the inserted 4-40 rod and throw can be adjusted by running the aileron fitting along the rod's length.
