RCU Forums - View Single Post - AM Cross - Split Elevator Servo ???
Old 05-04-2002 | 03:17 AM
RCP57
My Feedback: (25)
Default AM Cross - Split Elevator Servo ???
Why is it preferable to use two separate channels when utilizing two separate elevator servos? Why is it better than using a MPI Miracle Y. I know how to and have used separate channels for each elevator servo but don’t understand why it is the preferred method. I feel it should not be the preferred method simply because two servos in two separate channels will not run at the same speed due to the slight difference in the signal getting to the servo.
