No 9Z ...... Just a 9C
AnnMarie
An MPI Miracle Y is a connector that allows you to adjust one servo neutral point so that it matches the other servo. It also reverses one of the servo directions. With this device I can not see any difference between the two servos.
Unfortunately I do not own a 9Z. My talents just don’t warrant that type of investment in a transmitter. I have wired several airplanes using two separate channels, using both the 8U and the new 9C which is the radio I’m using. I feel it is very easy to see the difference between the two servos when they are put into two channels using either of these transmitters. Maybe I’m being too critical and it really does not matter if one half of the elevator is slightly slower than the other. Does it really matter? What does this condition cause?
