Early ? Xicroy gear brake controller programming problems
When I get the gear to operate correctly to the switch position the brake only operates in the up position etc.
I seemed to have re run the programming 40 times including varying the endpoints on the TX. DX18 frame rate 11.
I am having some effect because when I operate it with a servo tester as the signal it has moved the trigger point to retract.
HELP
Charles
