wow, Wow, WOW, all I had to do was reverse the gear leads!!!!
I know I have at least 6 hours in on trying every trick I thought I knew with controllers. I just did not think it was accepting the data points.
I just go it to function in 5 minutes.
I did notice the brakes will hold enough to flex the prolink knuckle at just over 1/4 brake slider and that would burn a flat spot. At least the maiden flights will be on grass.
will now try Len's polish trick to help smooth out the braking a little.
Much thanks
Charles
