Originally Posted by
paladin
I had the 2500 in mine, I had to quite it to 98 db, the chocking that required lead to the phrase sicker tiger. cause it was always needing attention, but enough about that. either of your engines should fly it nicely. how is the wt of the airframe, and what is it already set up for? I had the e and r servos in the tail and did not have to add dead wt to balance it. mine started life as a trike and I moved it to a tail dragger down the road.
joe
Not sure of the weight yet but it does have a lot of washers for weight up in the nose section. That’s why I was thinking of the S2500 instead of the G2300. Assuming they both run well, the CG will determine which engine I’ll go with. What’s interesting is the S2500 has a smaller carb than the G2300.
I told you it was ugly!
G2300
S2500
