RCU Forums - View Single Post - SAFE Rx setup questions/concerns
Old 04-18-2018 | 06:22 AM
AndyKunz
Originally Posted by H5606
Thanks very much for your help, for getting me out of the comfort zone, and for trying something new.
You're welcome. At the time I developed the wireless trainer interface, I was the main instructor at the club. I had a captive test group
Another observation: tried to set up failsafe on master as "preset failsafe" with all surfaces to max right deflection, up elevator, and throttle off like I've done successfully with other Rx's. Correct me if wrong but suspect the SAFE receiver is already programmed for failsafe and cannot be changed through the traditional means; testing failsafe feature by shutting off the Tx does show slight aileron input and throttle shutoff which satisfies me for this airplane.
Failsafe is handled differently with different receivers. The AR636 does not have the preset failsafe functionality that is found in higher receivers like the AR8000.
Andy
