I appreciate this really valuable information. I do NOT recall this information being in the directions that come with the controllers. When I called the supplier about the lack of proportional braking the answer provided was that to get it, I would have to go to the Pro Controller. Maybe meaning that even the suppliers do not know the above information? This type of information would be a lot more helpful if it was in the instructions that came with the product. But, thank you for being around to help us out.
I still have the Basic controller sitting in the junk box. When I initially set it up per the instructions, with -100% and +100% on the transmitter on the right slider, the brakes appeared to be on or off as I moved the slider (i.e. no brakes and then full brakes). The slider only had to be moved two clicks to go from no brakes to full brakes. In order to get more movement on the slider to go from no bakes to full brakes, that is when I installed the Pro, which seems to have given me more slider travel. It is probably not set up per the above instructions either.
Think I'll get out the instructions, set it upon the bench and play around with what you are suggesting.
Oh, is the above information also true for the Pro Version?
