RCU Forums - View Single Post - Early ? Xicroy gear brake controller programming problems
Old 04-19-2018 | 10:00 AM
Gaspar's Avatar
Gaspar
Originally Posted by Len Todd
Thank you for your help, knowledge and understanding. I am sure it will help many of us.
With the LGC12 and transmitter's Brake channel set at -100/+100, if the zero to full braking happens in two clicks (about 1/10th) of the slider's travel, how do I spread that braking out over the entire travel of the slider?
This just mean that the radio is not learned correctly, first connect an old servo to the brake channel in the receiver to confirm that it moves linearly according to slider position, once confirmed this, just redo the procedure described above. Often there are hidden mixes in a particualr channel that are very easy to spot when using a servo, but difficult to see if using an electronic Device like a valve, servo, etc.
Gaspar
