My Element Down thrust?
Hey guys, my Element down thrust with the stab at an accurate 0° is -4.5° down. This is like 3.5°more than I normally use. The stab is non adjustable. My bolted on t-cant is.55°+ to the stab and my wing is set @ .7°+ to the stab which means my t-cant is .15° negative to the wing. The real big issue here is the huge amount of down thrust @ 4.5° negative? From what I have read most people are using around a -1° to -1.5° down thrust.Wing is adjustable as well as t-cant and painted nose ring (3 colors) could be re done with a lot of work so that could be re- done! Grr Any thoughts on this will be welcome and aporeciated .
