Dave,
Thank you for the clarification. I think I got the lineup now.
Now as far as the fuel lines or concerned you are recommending to stick to the for 4MM supplied lines. On my other big jets that are in series I use 6MM fuel line or a 3/16 tygon. I also use high flow set up inside my tanks as well.
Do you not recommend I swap that out for 6mm or 3/16 tygon in the mephisto since it is in series?
I do a lot of aerobatics and a lot of inverted flying and I've had a few flame out because off not having the proper fuel lines and auto restart saving me in the past.
I want to make sure that this parallel set up is quite different than all my series set up.
I have a BF300 as the power plant.
Chet
