HI Dave,
No, you do not remove the heatshrink. When you pull the battery out of your 9Z you will see a connector where the row of pins inside the 9Z connected to it. You will insert the HSP78050 into this, this will then allow you to use a charger/discharger/cycler with this battery. But to do this you will need to also purchase the round connector that plugs directly into the battery case and this part number is HCAP0101. Nothing actually hooks up to the discharge connector itself.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (
http://www.futaba-rc.com)
