Hey guys, are you putting the batteries all the way up in the nose to CG or are you finding that not necessary? Also what battery sizes are you all using? I have to two 2s lipos 2100 mah for the receiver and one 2s lipo 2700 mah for the turbine. I hope to have the maiden done by the end of May if all goes well. After the maiden I will be using the Joker as my trainer jet and hopefully can get my waiver by end of summer. I was hoping I do not have to put the batteries all the way in the nose. I want to be able to charge them outside the aircraft. If they are all the way in the nose it will just be a hassle having to take the nose off to charge batteries.
