RCU Forums - View Single Post - Fx32 offset mix
Thread: Fx32 offset mix
Old 05-05-2018 | 12:01 AM
skywarrior's Avatar
skywarrior
Default Fx32 offset mix
Hi I want to use a two position button switch on my stick to operate gear metro Nic air valve.i have been trying to understand the offset mix option but am not sure if you fill in all four screens or are they just all the options that are possible.
can anyone give me a step by step example on what I need to fill in order for this to work please.
it needs to be a latch switch system ie press once for up and again once for down. Is subtrim involved in this set up ?
Thank you
David
