RCU Forums - View Single Post - Transport damage :-(
Old 05-10-2018 | 12:00 PM
KenKi6
Originally Posted by jarndice
If you look at the front of the hull on the inside of the front plate you will see a lip,
If you look at the front of the body you will see a tongue,
Place the tongue of the body under the lip of the hull and lower the back of the body onto the locking plate,
The front of the body and the hull should mesh with hardly any gap'
Do make sure you have twisted the 4 air cleaner pipes on the back plate backwards out of the way of the tank body.
Shaun.
The tounge and lip seems to fit. I’m not sure there’s air cleaner pipes that I can twist. I’ve followed the instructions in the manual, but can’t get the top to click back in place. I have another look to see if there’s any pipes in the way. Thank you for replying.
