Originally Posted by
757jonp
There's an excellent explanation of how his odd fire or multi cylinder ignition works on his website.
I understand how the reverse polarity magnet triggers the board to start the sequence. It was just hard to grasp at first during the phone conversation.
757jonp
I don't think going that low on oil is a good idea on a Saito radial. Unlike the Evolution radials, the Saito has a "dry" plenum and depends on oil bypassing the piston rings for lubrication. The evolution engines gets away with much less oil because the crankcase is used as the intake plenum and has a dry top end.
You could always use a supercharger on it and quit fooling around.
If the gas fired Saito radials can run on 15:1 (6.2%) oil, the alcohol version will get a lot more oil at 10:1. (9%) Especially considering 40% more fuel by A/F ratio. 9% /6.2% x 1.4 = twice the lube available.
