Wanted to let everyone with Assist receivers know that while we are still working on an update for firmware, you can run an assist on the CB100/200 and still run Dual Path or Dual Band and have a backup.
This will require using only the RX1 port on the CB200. Your Assist receiver will be the primary and will be connected to RX1 from either E1 or E2 in EX Bus. You will then set the unused E1 or E2 port to PPM input. Your secondary receiver is set to output ppm positive and plugs from the correct port (receiver specific) to the port you set to ppm input on the primary.
You will set the Assist to “Stabilize EX Bus” under Advanced settings and change the failsafe to Assist disabled. This will allow the radio to switch between receivers without needing the CB to make the determination of lost signal. All alarms will function as normal.
Zb/Jeti USA
