Originally Posted by
BobH
Jimmy,
I asked about the fuel bulb because when I pumped mine fuel leaked from around the base of it. I don't know why. I replaced the bulb thinking it had a hole in it but it didn't.
Does yours leak fuel when you push it?
Just wondering here.
Thanks buddy.
BobH that’s normal, your bulb is fine. If you look closely you will see there is a nipple that looks like a fuel line should be on it and that’s where the fuel flows from. It’s a one way outlet to prevent pressure from building too high once the fuel has reached the.bulb. The fuel simply pumps out of the nipple once the bulb is full. Hope this helps
