Originally Posted by
1QwkSport2.5r
Junky design. There should be a bearing in there that centers the gear and prevents the one way clutch bearing from rubbing. If you want electric start, I would stick with the EZ Start system instead. Otherwise you could try a Tiger Drive.
I got the same one on my .26 red dot and it works fine. I don't know if the ez-start can spin my .26 red dot. I use a double battery and double motor roto start. I have a single also and it doesn't cut it.
