its time to rebuild the yellow wing ... I had enough of broken retracts so I designed this holder , that utilizes the broken original retracts. printed it and build in. after that it came to a point, where again something went wrong. while landing, the engine shut down and i was trying to bleed airspeed it sudently again dropped the wing. The positive fact is that fuselage is quite intact. the wing would need again some rebuild, but i guess it already deserved it so I will replace the area around retracts. I guess, that the troublemaker are flap servos. they seem to not have enough force to keep them extended inflight. as the speed drops it tends to extract furthermore and breaks the aiflow so the wing drops in stall. Do you have this issue or how do you solve that? using some kind of lever or just stronger servos?
