https://www.nitrorcx.com/56h-x5hw-fpv-blue.html
Syma RC introduces its latest X5HW Quadcopter! A quadcopter is a machine that is lifted and propelled by four rotors. Unlike most helicopters, a quadcopter use symmetrically pitched blades mounted on four motors to produce lift. Controlling the speed of these individual motors allows the machine to move forward and backward, up and down, strafe left and right, and rotate clockwise and counterclockwise.
The Syma X5HW 4 Channel quadcopter brings a new element to radio control quads and offers a completely different experience of flying. It offers a refreshing change on how to hover, balance, and control a copter. With the help of an 6 axis gyro, stability and agility is achieved effortlessly. Flying the Syma quad is simple and intuitive allowing the pilot to enhance their skills quickly. The hover mode allows the quadcopter to hover in one spot allowing the flight control to take over and achieve altitude hold. Now you don't have to keep adjusting throttle as much while you are recording or flying FPV. Once you enhance your skills enough there are stabilization settings built in that you can disable to advance your ability to fly the X5HW and perform 360 degree eversion. The X5HW is also equipped with an HD camera to capture all your flying adventures.
With the use of 2.4ghz technology the Syma X5HW radio system has the benefit of longer control distance, strong anti-interference technology, low power consumption, and rapid response times. Using spread spectrum technology for further remote distance, best anti-interference ability, least power consumption. you could fly more helicopters at the same time, its reaction speed is 100 times faster than other radio control.
The Wifi Feature allows the user to connect to their mobile device with the Syma app. This allows the pilot to control on-board features and recording functions such as video, picture, and even flight controls. True FPV function is achieved by using the mobile device as a monitor while using the transmitter joystick as the flight controls.
The Syma Radio Control brand is one that is very well known in the micro helicopter industry. Its quadcopters has been a hot seller mainly because of its stability and ease of flight. The Syma X5HW Quadcopter carries all of these favorable traits over from the other quads to produce a quadcopter in an awesome ready to fly package.
The Syma X5HW comes ready to fly with a 3.7v 500mah Li-Po battery and charger providing about 7-9 minutes of flight time per charge.
Main Features:
Low-voltage protection
Over-current protection
Level calibration function
3D overturning function
With orange and green LED light
Pressure hovering height adjustment function
0.3 mega pixel camera
WiFi real-time transmission aerial photo-taking / video recording function
Fine tuning function
Fling-fly action
Headless mode
Left and right hand throttle mode switch
Specifications:
Brand: Syma
Item No.: X5HW
Version: RTF
Quad Size: 33 x 33 x 11cm
Motor Diameter: 0.8cm
Charging Time: About 130min
Flying Time: 7 - 9min
Frequency: 2.4GHz
Gyro: Built-in 6 Axis Gyro
Channel: 4
Camera Pixel: 0.3-mega-pixel
FPV: WiFi
Control Distance: About 100m
Battery: 3.7V 500mA Battery
Required to Fly:
4AA Batteries
