i have to take that back. it looks like the cb200 DOES support EXbus.
Features:
- Control Management with Configurable Servo Output
- Power Distribution with Two Independent Inputs
- Firmware Updatable via Jeti USB Adapter
- Jeti Duplex EX Bus or PPM Compatible
- Wirelessly Programmable Using DC/DS Tx Device Explorer
- Independent Receiver Signal Inputs (SAT1, SAT2)
- Up to 15x Servo Outputs with Overload Protection
- Up to 3x Telemetry Sensors Inputs (Ext1, Ext/14, Ext/15)
- Input for Included Magnetic or Optional Wireless Switch
- Input Voltage: 3.5-15V
- Output Current: 2x 10A Continues/90A Peak
- Dimensions/Weight: 62mm x 38mm x 16mm/30g
