Originally Posted by
Jack Diaz
No Dave .... "you use both receivers" !! Only that channels 16 and 17 are connected to one of them ... it really doesn't matter to which one.
You should NEVER connect any devices that use any significant power to a receiver powered by a CB200 unless you add additional power inputs directly to the receiver. The RX1 and Rx2 ports of the CB200 for example are capable of 300mah MAX!!!! A single servo connected to a receiver powered only by the CB200s RX port WILL destroy the central box and most likely result in a crash unless you also power the receiver directly from another power source.
