Originally Posted by
wfield0455
You should NEVER connect any devices that use any significant power to a receiver powered by a CB200 unless you add additional power inputs directly to the receiver. The RX1 and Rx2 ports of the CB200 for example are capable of 300mah MAX!!!! A single servo connected to a receiver powered only by the CB200s RX port WILL destroy the central box and most likely result in a crash unless you also power the receiver directly from another power source.
Wayne: did you read my post # 886 ???
Here is a copy paste
Dave, in Device Explorer, assign channels 16 and 17 to outputs ports 1 and 2 of your RX3. Power patch port 3 of RX3 (a Y from one of the CB200 servo outputs). Output 4 of RX3 goes to CB200 as usual.
Use low power demanding things as channels 16 and 17 connected to RX3.
That's the way I have it in some of my planes.
The important issue is the power patch !!! CB200 won't handle more than 200 mA from ports RX1 and RX2.
Regards
Jack
