Originally Posted by
ww2birds
Just to make sure I understand. "Both receivers" are used for all channels except 16 or 17 .. the CB picks the primary or secondary .. but 16 and 17 can only be fed by the RX they are connected to, right? So in the (admittedly unlikely) scenario that one of the RXs has no signal (e.g. one might be 2.4 and one might be 900, and there is some interference on 2.4), and that's the one with channels 16 and 17 .. then there would be no signal for 16 and 17.
Is this correct or not??
Maybe some Jeti magic I don't know?
Dave, both receivers are receiving and sending 24 channels to the CB via EXBus.
On Device Explorer you define which of the 24 channels correspond to each servo output of the CB.
Also, on Device Explorer you define which of the 24 channels can be outputted thru the servo outputs of RX3 (or whichever receiver you use).
And yes. If the receiver where you have 16 and 17 connected dies, those channels are lost ( use them for wipers and horn
