RCU Forums - View Single Post - Jeti DS-24
Thread: Jeti DS-24
Old 06-01-2018 | 09:38 AM
  #901
wfield0455's Avatar
wfield0455
My Feedback: (7)
Originally Posted by ww2birds
thanks all. I went back and edited my original posts to note to error in my initial statement that CB200 does not have EX bus out .. since it does!
I hooked it all up with channels 1-14 run by the CB200, pin 15 of the CB set to EX Bus out, and the remainder of the EX signals translated to S-Bus with the same channel numbers via the SlinkE device connected to pin 15, feeding the Sbus line to the devices on the nose of the jet, power fed from a servo port on CB200. Works like a charm :-)
I may do some further testing .. perhaps since pin 15 can also be a servo output, settable to EX bus, it might do more current than a dedicated EX bus output and not have the EX bus pin current limitation.
thanks for the clarification on the devices, Carsten. Do you and Sandor have that new Jeti device for sale yet?
Dave
By Pin 15 do you mean the EXT port or one of the 2 ports that can also be configured as servo ports ? I don;'t have a CB200 handy to look at but the servo ports are fine, the EXT port is not. The current limitation is for Rx1, Rx2 and EXT. So while the EXT port can be configured for EX Bus output, it isn't a good choice to connect an SlinkE and use that to drive SBUS servos but the ports that can be configured as servo outputs also, should be fine, I just can't remember if that's 13/14 or 14/15...
