Originally Posted by
gapellegrini
David I will try this. I have not yet tried because I need a Jeti Box to take the rx out of clone mode if I want to.Is that correct?
I donīt have the Jeti box.
Yes a Jeti Box is helpful. But first try to re flash the R3 with firmware again.. not sure but possibly will remove the clone mode and back to standard mode. Also if you are comfortable you can use the Jetibox emulator on your transmitter to get into the clone receiver
DavId
